How to Identify Relays & What Relay is this
Old Jan 7, 2006 | 06:58 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Im wonderign if there is a way to identify relays by using the numbers that are on them? Does anyone know if this is poosible/ how to do it. Also I believe this relay is the MAF burn off relay, is that correct or is it a different relay?
Old Jan 19, 2006 | 02:18 AM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Check a wiring Diagram!
Old Jan 19, 2006 | 04:14 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Yes, that's the MAF burn-off relay.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
