ECU help for my S-10
Old Jan 31, 2006 | 08:37 AM
BKB's Avatar
BKB
Engine: 305 tpi
I have a 87 2.8 5-speed 4/4 s-10 with the 1227429 ECU, i have been trying to use WinALDL with no luck. It seems it will not work with this code. Everthing i have read says i can use a 1227747 from a 4.3 and just swap my chip set into it. Is this true? What year body style will have the 1227747 in it. Is this the best ECU to use for tuning? I have been resurching this for some time and just not finding good info on the S-10 boards.
Old Jan 31, 2006 | 11:11 AM
5.0 10's Avatar
I dont belive it works that way. I think you can only swap chips from one 7747 to another. You should be able to use WinALDL with your truck. Is your interface known to be good
Old Jan 31, 2006 | 10:28 PM
BKB's Avatar
BKB
Engine: 305 tpi
I have built 2 cables neither work on my truck. I have been told the computer in the 87 2.8 was very hard to get the ALDL to work and cant be reprogramed.
Old Feb 1, 2006 | 11:50 AM
5.0 10's Avatar
I have to admit I've never tried to read a 2.8TBI. I've only worked 2.8MPI. WinALDL worked perfect for my buddies 87 2.8 firebird and his 89 4.3 Astro
gixxer92
Apr 12, 2022 12:09 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
tuningnewb
Sep 23, 2015 07:06 PM
