Big Stuff 3 ecm
I'm planning to go this route on my twins project. Dual WB02 in closed loop, perfect for Banks TT manifolds with two downpipes. It'll also support EGT sensors. Pretty sweet. No experience with it yet though ...
I was looking at this too until I found out the injectors are reverse driven -/+ or something, OK if your starting from scratch. I found a local who is a dealer/tech installer for Megasquirt and some other european ecm-so for the expertise I'm going with him.
Car: 25th Anninversary Z28
Engine: Pro Charged 355
Transmission: Built 700R4
That's the first i heard about the injectors thing. Everyone i have talked to says it basically a direct fit with no issues. Except that you may lose your factory tach. Hmm.
Ive got two big stuff systems sitting in a box at home. Ones going on a twin turbo 383 and the others going on a NA 572. Il post update once ive got the first one installed
