83 computer question
Old Feb 4, 2006 | 01:57 PM
z28maro's Avatar
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
ive got an 83 z28 im looking to take it more old school and strip out all uneccesary wiring, so what kind of probems will i have to remove my computer, im running a carb and an auto tranny. i guess what im asking is when i take it out what if anything will i have to re-wire
Old Feb 4, 2006 | 11:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
make sure you have the old school distributor not needing vacuum advance
then if you have a lockup tranny, you'll need to wire in a switch for the lockup
pull the bulb on the check engine light
and you're good to go. Then as long as the car runs, find any wires that are dangling, and cut them. that's what i'm doing now
Old Feb 6, 2006 | 05:01 PM
z28maro's Avatar
thanks, how do i know if i have the lockup tranny, all i know is that its stock and im sure i could figure it out but if you know where the wire(s) are so i could tell that would be awesome. thanks
Old Feb 6, 2006 | 06:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'm not sure what year they had lockup torque convertors. You have the 3spd th-350?
Try searching in the trans forum.
Old Feb 14, 2006 | 06:51 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
'83 is the first year for the 700R4 in the Camaro.It was the only optional auto for the Z28.Your car should have a lock-up torque convertor if it still has the 700R4 in her.The 200C was still availible but only in the Sport Coupe,and maybe the Berlinetta.The TH350 wasn't offered in the 3rd Gens.
And like Sonix stated you'll have to run a non computor controlled carb and distributor with a vacuum advance,unless she's just a strip car.Maybe instead of cutting the harness neatly tie-wrap and bundle the harness out of the way.This way if you ever decide to sell or change her back it won't be as much of a pain.
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
