ECM Housing as ground?
Old Feb 21, 2006 | 06:56 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Howdy!
I'm doing a custom TPI install into my pickup, and I'm wondering if it'll be a problem if I use my ECM housing as a ground distribution block.
Its a 7730 ECM, with the 4 screws running along the bottom, so my plan was to hook the four ground wires from the ECM directly to it's housing, then run a big ground wire from one of the retaining screws on the side to my my cab's primary ground block.
Any reason why this would be a problem? Figured it'd make for a cleaner install, and 4 less wires to deal with (my ground distribution block is full less one wire left.)
Old Feb 22, 2006 | 06:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
All ECM grounds are to the engine. None including the case are grounded elsewhere.
RBob.
Old Feb 22, 2006 | 01:33 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Hmm... Interesting!
I've basically built my harness myself, and as such, had no idea how the grounds hooked up originally...
Might have to look into getting myself a peice of wiring harness that has some good grounds on it
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
