165 swap problems
Old Mar 21, 2006 | 07:01 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
165 swap problems
Hey guys....
I just swapped an 89' ecm into my 85' z28. Now it won't start! I think it is a fuel issue as i do not hear the fuel pump priming Sugestions? Although I did modify the prom, I think I eliminated the possibility that the ecm or the prom were bad when i plugged in an unmolested 87' ECM that was working when i pulled it out of its original car. Is there anything that problem could most likely be? if not... i guess Im gonna be weeding thru some wiring today
Old Mar 21, 2006 | 07:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Try this site out:
http://www.eecis.udel.edu/~davis/z28/
Mike has a lot of info on the swap you made.
RBob.
Old Mar 21, 2006 | 03:27 PM
I followed those directions.... no fuel pump prime. I have even tried two different ecms. obviously somthing isnt hooked up right. I just need to know what part of the swap i would need to screw up in order to prevent the fuel pump from priming? How the 2 maf relays are hooked up wouldnt stop the pump from priming right? I just want to narrow down what it could be.... nothing on the list of repinnings appears to have much to do with the fuel pump.
Old Mar 23, 2006 | 07:49 AM
could hooking up the 2 maf relays wrong have anything to do with no fuel pump?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
sreZ28
Aug 14, 2015 07:48 PM
