ECM PCB coating?
Old Apr 23, 2006 | 09:32 PM
HaulnA$$'s Avatar
ECM PCB coating?
I need to modify an ECM board and I cannot find anything that will remove that thick conformal coating. I have tried denatured alchohol, laquer thinner and acetone (nail polish remover, no, not mine, the wifes) and nothing works. Anyone have any success removing this to be able to cleanly solder on the board? Help!
Old Apr 23, 2006 | 10:29 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
the heat from the solder will remove it.LoL
Old Apr 24, 2006 | 12:24 AM
HaulnA$$'s Avatar
The whole point is to remove the coating BEFORE taking the soldering iron to the PCB. Solder joints are easily contaminated. Anyone who has fought a "cold" solder joint knows that a clean solder joint is a reliable one.
Old Apr 24, 2006 | 06:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I use brake cleaner. The stuff in the red can is more aggessive then the green can stuff. Tooth brush helps too.
RBob.
Old Apr 24, 2006 | 08:45 AM
HaulnA$$'s Avatar
RBob.
I'll try it. Thanks!
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
