16196285 ecu
Old May 12, 2006 | 05:59 PM
kyanox's Avatar
16196285 ecu
I know this ecu isn't for the 8 or 6 cylinders, but I'm heading up the J body ecu project and I've got some questions.
We've found a lot of data, but have some tables that are since still a mystery and someone suggusted i walk the code. Problem is, my assembly is like a 1st grader trying to figure out calculus.
Here's what i've commented from the data part of a subroutine so far. Can anyone tell me if i identified what each line does correctly and if this subroute is related to ADMAT.
E9E5: LE9E5 BRSET L00C3,#$04,LEA25 ; Branch to LEA25 if L00C3
bit #$04 is set.
E9E9: LDAA L00EB ; Load L00EB to acc. A ;
ADBAT BATTERY VOLTAGE, A/D COUNTS
E9EB: CMPA L3697 ; subtract L3697 from (ADBAT)
L00EB and set condition flag
E9EE: BHI LEA25 ; Branch to LEA25 if L3697
higher than acc. A carry clear flag
E9F0: BRSET L00CD,#$20,LE9FF ; Branch to LE9FF if #$20 is
set at L00CD
LE9F1
E9F4: BRSET L00CD,#$40,LE9FF ; Branch to LE9FF if #$40 is
set at L00CD
E9F8: LDX #$1806 ; Load 16bit #$1806 into X
E9FB: BRCLR $0000,X,#$40,LEA25 ; Branch to LEA25 if $0000
bit #$40 is clear
E9FF: LE9FF BRSET L0092,#$01,LEA15 ; Branch to LEA15 if L0092
bit #$01 is set
EA03: LDAB L3699 ; Load L3699 into acc. B
EA06: BRCLR L009A,#$01,LEA0D ; Branch to LEA0D if L009A
bit #$01 is clear
EA0A: LDAB L3698 ; Load L3698 into acc. B
EA0D: LEA0D CBA ; Compare acc. A to acc. B and set flags
EA0E: BHI LEA15 ; Branch to LEA15 if acc. B is
greater than acc. A
EA10: BCLR L00A4,#$20 ; Clear L00A4, Bit #$20
EA13: BRA LEA20 ; Branch to LEA20
Thanks for the help in advance, while I'm a newbie I might seriously be the only one doing Jbody stuff. If not, I would contribute what i've learned for anyone else.
Also, the above ecu is a $36 mask template that we're working with. There's a similar ecu 16191947 which i have a file that uses the F1 mask, and ecu 16168505 for the chevy S10 that uses the LN2 engine.
gixxer92
Apr 12, 2022 12:09 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
tuningnewb
Sep 23, 2015 07:06 PM
