4l60E swap
4l60E swap
Is anybody running a 4l60E behind a TPI engine? If so what are you using for the ECM and which code are you running? I curently have a speed density TPI with a 350 tranny. I can get a great deal on a 4l60e wich would be great for the over drive becasue of the 5.13 gears i have in the rear. Is how would i run this tranny with my tpi
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Take a look at the mid-90's TBI/CPI truck PCMs. They can both control a 4L60-E and run TPI, with some minor mods.
I did it for a while, but I messed up on the wiring and it wouldn't shift out of second, regardless of the column shifter, aside from reverse, park and neutral. I ended up getting the TCI controller for it, made adjusting shift points and line pressure way easier.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
Hello, Michael
Aug 20, 2015 03:19 PM
