coolant sensors on older MAF tpi apps
Old Jun 13, 2006 | 03:15 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On the older TPI apps ($32) there is 4 coolant sensors. 1 head goes to gauge, one head goes to fan switch, front of intake has two. One goes to ecm (which one?), the other goes to ???
I'm gonna repin my vette to a '730, and replace one of the front coolant sensors with the later style sensor and plug, but need to know which sensor is for the ECM, and wtf the other one goes to. None of my fbody or ybody manuals have 2 sensors listed in the intake, but i've seen NUMEROUS older TPI setups with two.
-- Joe
Old Jun 18, 2006 | 04:11 AM
LittleNo's Avatar
Car: 91 TPI Caprice
Transmission: TH700R4
the coolant temp sens has black and yellow (same at newer TPIs)
i guess the other one you're talking about is the cold start switch - if you convert to 730 ECM, just leave it blank, you don't need it anymore (the cold start function is included in the software of the $8D mask)
Old Jun 20, 2006 | 08:35 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Yup exactly the other one is the cold start temp sensor. It should be the one more to the left.
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
