Can I Bench Test 02 Sensor?
Old Jun 17, 2006 | 09:00 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Does anyone know of a way to bench test a one wire 02 sensor?
Old Jun 18, 2006 | 01:15 PM
Scotty27's Avatar
Car: 1989 IROC
Transmission: t5, wanna be a t56 when I grow up!
Axle/Gears: Whatever stays bolted on behind me!
Old Jun 19, 2006 | 11:33 AM
Drac0nic's Avatar
get a digital volt meter. (high impedance) If I'm not mistaken you will probably have a 1 wire sensor, if so connect the negative lead from the meter to the metal shell, and the positive lead to the connector wire. Take a propane torch, and heat the sensor up; you should be above 650mV or so, and it should vary when you move the tip back and forth.
Old Jun 23, 2006 | 09:08 PM
Excellent! That's what I was looking for. Buying a new o2 sensor every time it's suspect to being faulty didn't seem too appealing, so I'm glad to see there's a way to test them. Thank You!
Old Jun 23, 2006 | 09:46 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Honestly...I would replace it if you seem to be having bad mileage and/or codes.
The reason is that you can't bench test it for cross counts to see how many you are getting in a second. Also, I would only buy Delco sensors...do a search to see why the others suck.
Good luck.
Old Jun 28, 2006 | 09:19 PM
Thank you for the info! I will check it out
83 Crossfire TA
Jan 3, 2016 01:26 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
