code 43 = stupid ecm.
Old Jun 27, 2006 | 08:44 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
i need to replace my ecm aperently i will find out for sure tommorow when i put it on the computer at work, but i ran the codes and it said code 43 which is knock sensor ecm and so on but im getting the symtoms of a bad ecm, so i decided to look into it and see what i need. of coaurse i need the ecm but should i get a new prom with it or just pull the original? and were is the best place to get one? i check out one of our sponsors (TPI PARTS) and they have some used ones for 75$ with out the prom..... is this a good way to go or should i go with a new one for 140$?
Old Jun 27, 2006 | 11:05 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Have you checked the voltage to the knock sensor yet?.if so what was it?..If its over 6 volts ..make sure its not to close to ignition wires(plug wires)and its not shorted to voltage(wire that has power) or its like you mentioned faulty ECM..If its lower then 4 volts the wire is shorted to ground or its a bad ECM.If the wire is below 4 volts and is not shorted to ground most likey the ECM has an open circuit.Its possible a faulty mem-cal could be drawing the voltage down.Anyhow you should see 5 volts at the sensor.Hope that helps
Old Jul 24, 2006 | 01:34 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
You also should check the knock sensor for the proper ohms.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
Luigytico09
Oct 1, 2015 08:46 AM
