Reading in 8192 at a 9600 baud rate...
Old 07-27-2006, 07:50 PM
Former Sponsor
92blue's Avatar
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I'm writing a small app that needs to communicate via the ALDL port on a 8192 baud application. I've tried searching on here as well as elsewhere, but wasn't able to find any concrete answers. I did find a couple of places that implied using a standard 9600 baud rate will work fine with an 8192 baud data stream. Can anyone shed some light on the subject?
I know some of you guys have some experience with this, so I figured I'd ask here.
Old 07-27-2006, 08:32 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
You need 8192 baud. You get garbage if you use 9600.
Old 07-27-2006, 10:29 PM
Former Sponsor
92blue's Avatar
Car: 1992 Camaro RS
How do you go about reading in a nonstandard baud rate then?
I found a mention of this issue that I had missed in a previous search.... https://www.thirdgen.org/forums/dfi-...ight=8228+baud
Old 07-27-2006, 11:03 PM
Former Sponsor
92blue's Avatar
Car: 1992 Camaro RS
I've never done any serial i/o before, so this is all new to me.
If I understand correctly, to get the 8228 baud, I would have to set a divisor of 14 on a baud rate of 115200? Is that right?
Old 07-28-2006, 06:46 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
Maybe try looking into some third-party communications libraries that would allow you to set the baud rate numerically.
Depending on what platform/language you are using, here are a few that may help.
Old 07-28-2006, 09:56 AM
Engine: 5.7L TPI
The other annoyance you run into is serial port controllers that do not support non-standard rates. The USB<->Serial convertor with the Prolific chipset is one of them.
sahlomonic
09-20-2015 07:15 PM
eustodp
09-20-2015 05:09 PM
Bubbajones_ya
09-14-2015 08:38 PM
sandman92084
09-12-2015 10:27 PM
rsrookie
09-05-2015 07:08 PM
Quick Reply: Reading in 8192 at a 9600 baud rate...
