ECM identification and scan
Old Aug 3, 2006 | 06:55 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
My backup car has recently developed a hell of a problem. It's an 83 buick lesabre with a carbed 305. It started a week ago when I found a vacuum hose split. I replaced it, but the car was still running bad. I took it to a shop where they found my cat was melting and had destroyed my muffler as well. I've got an SES light, and I'd like to be able to read what the problem is. I've got a laptop and ALDL cable, but I'm not sure what the ECM is. I know that WINALDL didn't work when I tried to scan, but i might have just had a setting wrong. Is there any software available for this ECM? The O2 sensor is also powder coated black, and the spark plugs are also just as nasty. It runs like it has no power, even when floored, and spits out black smoke when driving.
Old Aug 5, 2006 | 07:48 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
as far as doing a scan on it i can't help you. you need to get the numbers off the ECM to find out which one you have & someone else may be able to help you out.
you can pull codes by jumpering A to B in the ALDL connector which would be a start.
i would recommend that you don't drive it with it running like it is or you will probably melt down the new cat pretty soon.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
