TBI/TPI 350's
Old Aug 5, 2006 | 09:13 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
TBI/TPI 350's
Is a TPI Chip the same as a TBI chip? I have a 1988 camaro that had a 305 tbi, and now has a 350tbi, but has the stock 305 chip. However, camaros never came with a 350tbi, so what do i do?
And if anyone has a 350tbi and has a chip that they really like, let me know.. i will buy one for mine..
Last edited by 83Chevy_Camaro; Aug 5, 2006 at 09:17 PM. Reason: Automerged Doublepost
Old Aug 7, 2006 | 07:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The TPI & TBI chips are not interchangeable.
IIRC the '88 TBI ECM is a 1228063, and f-body 1 year only ECM. Best bet is to find a '89-'91 (or there abouts, I am not sure of the exact years) Caprice with an L05. Get the ECM (1228746) and plug it in. It is pin for pin compatible with the '8063.
RBob.
Old Aug 7, 2006 | 11:07 AM
Car: 1988 Camaro
Axle/Gears: 2:73's
well that number matches.. heres a picture of the label..
I have a 350 TBI, with the 305 TBI chip. Is there anyway i can get a 350tbi chip that will fit into a 1988 camaro '8063 ecm?
I have a 1983 camaro berlinetta 305 4bbl carb Ecm.. can that be of any use?
Old Aug 7, 2006 | 11:11 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
RBobs response is your choice. I don't know of anyone who has reversed the 8063s code, meaning you are out of luck for a 350 version of the chip. Why even bother when you can get the whole ECM from a 350 caprice for $30.00 at a junkyard.
You could also use a truck/van/suburbuan/SUV ECM, but they typically are tuned worse from the factory than the car stuff. Timing is too late, too much fuel under light loads, weird TCC operation, etc. In short calibrated for 4,500+ lbs.
Old Aug 7, 2006 | 11:14 AM
Car: 1988 Camaro
Axle/Gears: 2:73's
So would i notice any diffrence by getting a 350 caprice ECM?
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
