727-D11 neutral safety switch N.O. or N.C.?
Old Aug 17, 2006 | 01:56 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Pin D11 on the 727 is for the neutral safety switch. What state indicates that the vehicle is in neutral or park, Open or closed? The switch just goes to ground... but I don't know what the ECM is looking for in order to actually start the vehicle.
Thanks, Charles
Old Aug 17, 2006 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The switch is not a safety switch. It only allows the ECM to know whether the trans is in park/neutral or drive.
Drive is open
Park/neutral is to ground
There is a separate switch for the park/neutral no-crank safety feature.
RBob.
Old Aug 17, 2006 | 12:34 PM
Transmission: TH350
So is the D11 pin for the IAC, to add a couple counts when put in drive?
Is the ECM involved in any way in the neutral safety for starting the motor while in drive. I was thinking there may be some code (programming) in there somewhere that would not turn on the spark signals if D11, or something else, was not in the proper state...??
Charles
Old Aug 18, 2006 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thee ECM takes no control over whether the engine is cranked/started in drive or park/neutral. That function is relegated to a separate switch.
RBob.
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
