Commander 950 Pro will not load.
Old Aug 27, 2006 | 05:24 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Try to load software into my dell laptop W/XP and I get this message.
""can't load (or register) custom control:COMDLG16.OCX"
What do I do?
Old Aug 28, 2006 | 02:37 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
ok, got it to work.
Next question is what do i use to communicate with the ECM. I don't have a comm port on my laptop. Only usb ports.
Old Aug 29, 2006 | 09:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Will need to get a serial to USB adaptor cable.
RBob.
Old Aug 29, 2006 | 10:02 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Would a radioshack have that kind of cable?
Old Aug 29, 2006 | 06:13 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I got one of those cables off ebay everywhere else seem to sell out of them as soon as they get them. Heres a link:
eBay: MOTOROLA DATA CABLE CE BUS/USB MPX-220 , (item 230019586776 end time Sep-15-06 23:45:30 PDT)
I had just bought a new laptop and used that cable but for some reason the newer laptop with XP and that Pro software wouldn't find the 950 PC. So I bought a old school laptop for $50 on ebay and it worked instantly with no problems at all. That laptop only has 2G hard drive and its more than enough for the software and thats all I use it for so I don't have to use my newer laptop for my car.
Here a link for one of those cheap laptops also:
eBay: Toshiba Satellite Back to School Laptop Computer USB (item 270023738177 end time Sep-01-06 13:24:11 PDT)
Old Aug 29, 2006 | 11:13 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
lilbowilson- Thanks for all that valuable information. New style laptops W/XP won't work with the 950 pro???
Old Aug 30, 2006 | 10:12 PM
Car: 87 IROC
For some reason the newer laptop took longer to load the software just like yours did and when I used the USB/BUS cable it still would not read the 950 ECU. Once I got that older laptop that ran on windows 98 the software loaded instantly and uploaded the program to the 950 with no problem. Now I just have to figure out how to adjust my programs.
Damn you got a killer setup there! When you get yours going give me some pointers on how to tune with the 950 OK!
Old Aug 30, 2006 | 10:41 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Thanks for the info. It'll be sometime before mine is running but I'll keep notes when she is going.
seiplentz
Aug 19, 2019 06:02 PM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
ULTM8Z
Oct 2, 2015 01:25 PM
BBSDesigns
Sep 22, 2015 03:08 PM
