Fack Computers
Old Sep 3, 2006 | 10:50 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Fack Computers
ECM's suck. I had to drive my car home at 250* because the sensor that turns my fan on broke... I cant wait to go all carb and have my friggin fans on a manual switch...
Old Sep 3, 2006 | 11:32 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
Ouch!
Man, you shouldn't have had to do that. Next time turn on the AC and your fan should come on. Also, I don't think the ECM comes into play in the fan circuit. I got sick of troubleshooting that junk too, so I wired mine this way:
Something to consider doing when you go carbed, or before. The "Temp Sw" box is this thing: Flex-a-lite Adjustable Electric Fan Controllers: FLX-31147 - summitracing.com
The whole rig is a total of about $35 worth of electrical stuff, and I never have to worry about it. I can set the circuit to turn on at whatever temp I want, then leave it alone...
Good luck with it, I hope you never have to deal with that problem again.
Old Sep 4, 2006 | 08:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can't blame the ECM, your '88 TBI L03 fan is not controlled by the ECM.
Same would have happened with a carb. The temperature switch in the head goes right to the fan relay. All you had to do was to ground that wire. Then the fan would have run and you wouldn't be cussn' out the innocent ECM.
RBob.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
