VATS Question
Old Oct 12, 2006 | 03:18 PM
extreme 1's Avatar
Car: 1989 gta
Engine: 350 tpi
Transmission: 700 r4
VATS Question
If there is a problem with the vats module,the car will not crank? I've been having a problem with no start,changed the starter,checked everything thing else.Thing is,when it will not crank,the security light on the dash stays lit whenever this happens,this leads me to believe that it is a vats problem.Any one have this problem?,and where is the vats module,wiring etc.........?
Old Oct 12, 2006 | 03:24 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
It most likely is not the module, but the wires from the ignition cylinder. If you want to bypass the VATS system, do a search for "VATS bypass" for the procedures.
Old Oct 18, 2006 | 10:11 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
VATs
I was running into the same problem. The VATs does 2 things, disables the started & does not pulse the injectors. It's a little hard to test because the VAT's sends a squre wave to the ECM on a blue wire, (can't reproduce it). I jumpered my started to make it crank, then checked to see if I was getting pulses on the injectors. I have a 91 GM manual with all the info, so let me know if I can help.
Old Oct 27, 2006 | 03:24 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
When the SECOND $210 VATS module c-----d out, I decided to be
rid of it altogether. As an alternative to programming it out of the
ECM, board member S10Wildside (also an e-bay power seller) builds
the square wave emulator for $15 plus shipping.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
