zz4 ecm/prom, is it a $400 dollar improvment over the lg4 chip for a350 swap?
Old Nov 10, 2006 | 05:16 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Wondering if it is worth $400 for the ecm/prom or should I just leave teh lg4 jet chip in it that I have now? thanks
Old Nov 13, 2006 | 01:14 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
For that price you can buy all the stuff needed to burn your own chips including a cheap laptop off of eBay! It may seem overwelming at first but its really not that hard to do.
I wouldn't spend that much. Look at the DIY Prom boards. Buying a chip is not money well spent.
Old Nov 19, 2006 | 09:19 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
But, there isn't much support for LG4 Prom tuning yet though. I've only briefly looked into it, though. Basically, you'll probably just want to adjust the ignition timing map, so not much support would be necessary. I'm pretty sure the LG4 ignition map is the lamest map ever. Not sure about the Jet. You'll also want to play with rods and hangers on the Q-Jet to get the full throttle A/F set right (maybe good enough already with your Jet Q-Jet).
But, if you're not interested in doing it yourself, $400 is a LOT for an ECU. Have you tried EBay? May have to wait around a bit for one to show up on there, but it might happen.
Might have some more responses or info on the Carbs forum.
Old Nov 20, 2006 | 06:20 AM
BLACK Z's Avatar
Car: 86 Z28
it is the prom and ECM, I can get the prom and ECM for about $30 from a 87 L69 monte ss? would that be better?
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
