Does a Differential Pressure Sensor & map sensor look diffrent? I want to make sure I
Old Nov 23, 2006 | 05:57 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
85 86 86 F bodies that where carbed used a Differential Pressure Sensor that is near the brake booster, a lot of people call it a map sensor but it is not does anyone know how to tell them apart? I want to make sure i have the right one.
Old Nov 23, 2006 | 08:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On the left top front of the sensor there is a 3 digit number stamped into the plastic housing. If comparing GM sensors can check that number. The 2 common MAP sensors used on SD EFI systems are 039 and 460. I don't know what is used for the differential pressure sensors.
Can also check the connector insert color. Most of them are color coded. I've seen blue & red inserts used for baro sensors on CCC cars (non-f-body).
Then green & black inserts on SD EFI cars (039 & 460).
RBob.
Old Dec 4, 2006 | 06:59 PM
BLACK Z's Avatar
Car: 86 Z28
Anyone else have any info?
Old Dec 11, 2006 | 06:27 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Dec 19, 2006 | 09:49 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Here is a link that lists the gm part numbers.
http://www.diy-efi.org/gmecm/compone...o/sensors.html
Old Dec 21, 2006 | 06:53 AM
BLACK Z's Avatar
Car: 86 Z28
It does not list th e# or info on the diff pressure sensor.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
