'7747 xdf and bin info
Car: 1984 Crossfire Injected Corvette
Engine: L83 Stroker
Axle/Gears: 3.07
.This is my first post but I have been lurking for quite a while. Enjoy every moment on this board, as well as CFI vault and others. I have two crossfire injected
corvettes, an '82 and an '84, both with significantly modded engines. I use prominator equiped 7747 ECMs for tuning, Tunerpro for editing and winaldl for data logging. I do not yet use WBO2 but will be adding soon to both cars. I have been tuning the 388 in my '84 for some time and have recently started tuning the 355 in my '82 using the same .xdf and starter bin. I have finally come to the conclusion that both .xdf files are corrupt. Can any one point me in the right direction to a bin/xdf file library specific to the modified SBC with 7747 ECM? (if one exists)
Thanks in advance for all help.
Gary
GJSZ51
corvettes, an '82 and an '84, both with significantly modded engines. I use prominator equiped 7747 ECMs for tuning, Tunerpro for editing and winaldl for data logging. I do not yet use WBO2 but will be adding soon to both cars. I have been tuning the 388 in my '84 for some time and have recently started tuning the 355 in my '82 using the same .xdf and starter bin. I have finally come to the conclusion that both .xdf files are corrupt. Can any one point me in the right direction to a bin/xdf file library specific to the modified SBC with 7747 ECM? (if one exists)Thanks in advance for all help.
Gary
GJSZ51
3rdgenparts
May 21, 2016 11:50 PM
Linson
Oct 1, 2015 09:50 PM
