Getting started
Car: 85 TPI IROC-Z
Engine: LB9
Transmission: 700 Bulletproof
Axle/Gears: 3:42
Getting started
ok i have read and read and then read some more. but the more i read the more i feel i should of started reading this forum MANY MANY MANY years ago.
can someone in a easy to under stand point me in the direction of getting started into prom burning?
what do i need to purchase to get started. my budget is limited, and my question biggest question would be... so far i only see needing to do this one time, (but if i had the equipt more times maybe)
I can have someone write the custom prom for me for $350. (unless someone know of somewhere cheaper) so which is better to do have it do for me or look into doing it myself?
Car: Death Mobile
Engine: 666 c.i.
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
If you have access to a laptop, you should be able to purchase just about all you need to burn your own for $350. There is a lot more to proper tuning than just a one time burn or paying someone for a single chip.
However, it is better if you enjoy learning about this stuff and like tuning on your car to get it really purrrrring.
Car: 85 TPI IROC-Z
Engine: LB9
Axle/Gears: 3:42
Yes i have a laptop, in matter of fact I have a few extras laying around...
where do i find this software and stuff?
Car: Death Mobile
Engine: 666 c.i.
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
1985 TA ECM QUESTIONS....
I JUST PICKED UP AN 85 TPI TRANS AM. MY QUESTION IS :
IS THE PLUG FOR MY ECM LOCATED UNDER THE INSTRUMENT PANEL IN THAT LITTLE ACCESS DOOR ? ALSO, IF I WANNA CHECK FOR ERROR CODES,WHICH PINS DO I JUMP IF YOURE LOOKING AT THE PLUG.
SHE STARTS ROUGH,BUT WHEN WARMED UP IT RUNS FINE.THE IDOL JUMPS FROM ABOUT 500 TO 1000 RPM WHEN IN PARK, AND INTERMITTENTLY THE ENGINE LIGHT COMES ON, BUT GOES OFF AS SOON AS YOU GIVE IT GAS.
ANY HELP WOULD BE GREATLY APPRECIATED. THANKS
Last edited by wrapper8758; Jan 10, 2007 at 07:16 PM. Reason: sorry...attempted new thread
92camaroJoe
Aug 13, 2015 06:07 AM
