Error Code 44,New 02 Sensor Installed
Old Jan 23, 2007 | 03:58 PM
wrapper8758's Avatar
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
I had a code 44 on my 85 TA 305 TPI .(lean 02 sensor). I replaced the Sensor,disconnected the battery and let her sit for about 30 minutes.
When I re-installed the battery, i took her for a ride in city and hwy driving for about 45 minutes to let Ecm "Relearn Data". the engine light came on at a stoplight,and back out again when I accelerated.It hasn't come on again.
I checked for error codes again , and code 44 is back. Any ideas?
thanks.
Old Jan 23, 2007 | 08:49 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it could be fuel pressure, dirty injectors, MAF problems including air leaks between the MAF sensor & throttle body or vacuum leaks.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
