88 formula ECM
Old Feb 6, 2007 | 10:49 AM
wano1147's Avatar
88 formula ECM
I have an 88 Formula that I put a 383 SB in and changed to a custom EFI system controlled by a Megasquirt ECM. The stock ECM is still connected and still controlling verything but the EFI. My question is, does the stock ECM have a fuel pump shut off triggered at high RPMs as a rev limiter. The EFI goes very lean at about 5000 rpm. I am running 29 pph injectors which should be plenty, I have even increased fuel pressure to 60 psi and the same thing happens, injectors are hitting 100% duty cycle, this makes me think fuel supply is being shut off.
Any input would be appreciated.
Old Feb 15, 2007 | 09:31 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
if your injectors are 100% Duty Cycle, that means they are constantly open. Also known as static.
You need higher fuel pressure(which you already tried), or bigger injectors. The bigger injectors will flow more fuel and hopefully stay within bout 80% of maximum duty cycle.
EDIT: Sorry, I missed that in the middle of the paragraph. Still, 100% Duty Cycle is still bad.
Old Feb 15, 2007 | 01:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No, it does not.
It may be that the fuel pump can not supply enough volume.
RBob.
Old Feb 15, 2007 | 03:17 PM
wano1147's Avatar
That's also a possibility I was wondering about, this was a TBI car but I installed an inline MSD high pressure fuel pump, maybe the stock pump in the tank cannot supply enough fuel to the high pressure pump at max HP. This motor should only be in about the 450 HP range and even Edelbrock says the 29 pph injectors should be big enough.
Thanks for the input.
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
Reese-J
Sep 14, 2015 02:43 PM
Jlanz55
Sep 8, 2015 11:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
