what went wrong?
Old Feb 12, 2007 | 11:50 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
what went wrong?
I got an 85 Iroc with rebuild 406 engine. I swaped my injectors to 30 lbs/h. Anyway when I broken my engine, I had the stock prom and ecm (870) and the car ran ok with hard idle. then, I swaped the ecm to 165 and modifed my stock wirring. for the prom, I used 6E and I disabled vats and changed my injector to 30lbs. now My car does not idle at all, and if I step on the gas my rpm goes to 1500~2000 rpm. I check the wiring few times and it seemed to be good. What could be wrong??
Thanks, Ivan
Old Feb 13, 2007 | 10:13 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
when you changes all this stuff , what did you do to thecold start ? Did you block it off ?
Old Feb 13, 2007 | 07:53 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I changed them all at once. I have no 9th injector because I am using super ram, and I did not disable it from the prom
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
