ecm/prom help please
Old Feb 22, 2007 | 10:07 AM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
Hi all, I am working on a 89 tbi 305, and almost ready to switch to carb'd because of my ecm/vats issues...I heard you can re program the prom to dissable vats...is there someone who can tell me how???or can help???
I've bi-passed everything vats dissables(starter, ign. coil) and the only thing I cant get is the injectors to pulse....I have spark at the plugs...fuel pump works fine...its just satisfing the ecm to give me pules to the injectors I lack.
I have a pass key module...and have a varable restor soldered in the key wires...and have adjusted it to all 15 resistences....but still no go. the security light just stays on with key on...
Old Feb 24, 2007 | 11:58 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Disabling VATS via the prom requires a simple change to the "VATS" switch.
I recommend that you purchase the eprom burning equipment as you will need to make further changes to improve driveability and performance anyway. FYI, on a bone stock L98, I improved my performance by 30 HP at the top end and 30 lb.ft TQ throughout the mid-range to the top-end, plus I increased my fuel economy.
If you just by an eprom, you will not obtain those same results unless you get a tune done "hands-on". With a mail-order, they just tune it for "good enough", so consider you are leaving 30HP & 30TQ on the table.
Go to the DIY Prom Board and there are "stickies" on the top which tell you everything you want to know about eprom burning.
Good Luck.
ffvetteman
Jan 31, 2012 08:17 AM
mattyc
Sep 13, 2010 09:50 PM
inittab
Jun 7, 2009 07:14 PM
CCrockett86
Jan 17, 2009 08:06 PM
v8nate92RS
Sep 13, 2004 09:51 PM
