Code 53= faulty ECM?
Old Mar 22, 2007 | 12:32 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
I am getting an intermittent code 53, 43, and 45. As soon as the SES light comes on the car surges chuggs and bucks back and forth then dies. I have to keep the pedal half way to the floor just to keep it running.
I have replaced the alternator and knock sensor along with countless other things hoping to fix this.
I think I have a fauly ECM or prom PLEASE HELP!
Old Apr 1, 2007 | 07:45 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: Code 53= faulty ECM?
When you first turn the key to the run position does the SES light blink? If not, bad ECM. If the PROM is bad, a code 51 should show up...It did in my 84 Berlinetta.
The loss of power does seem like as symptom of a bad ECM, when my Trans Am's ECM went bad, the light would come on and I'd lose power, and nearly stall, but no trouble codes were stored.
check for a bad connection to the ECM, that could cause intermittent problems.
BumpaD82
Feb 26, 2016 02:57 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
85 Jimmy
Sep 30, 2015 07:56 AM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
