check engine light
Old Apr 14, 2007 | 08:09 PM
95foxbigblock's Avatar
check engine light
well, is there a scanner for an 85 z28 carbed 305? i have an aldl
Old Apr 14, 2007 | 10:05 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: check engine light
If the SES light is on you can just put a jumper (paperclips will work fine) between the two top far right terminals, and the light will flash codes, code 12 will flash three times, then other codes will be flashed, in numerical order.
Flash, pause, Flash,flash is 12. flash,flash, pause, flash would be 21.
you can look online or here for the meaning and remedies of the codes.
Hope this helps.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
