datalog OBD II ?
Engine: 350TBI
Axle/Gears: 3.42 powertrax
datalog OBD II ?
Hi,
We own a '99 chevy Venture.
It has a 3.4L V6.
We have some braking problems :
Rear brakes don't work, Brake-, traction control- and ABS light are burning at the dash, trans. doesn't go in to 4rd gear annymore.
So I would like to scan the ECM to check the exact faults.
How can I do this on a budget ?
It's OBD II.
Thanks,
Gr.Dieter
It has a 3.4L V6.
It's OBD II.
Thanks,
Gr.Dieter
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: datalog OBD II ?
http://www.obd2allinone.com/sc/detai...item=obd2cable
This link might be of use, or you might look into Autotap.
Engine: 350TBI
Thank's,
And then I can datalog in TunerproRT, right ?
Is it possible to make such cable myself ?
Like I made my own 160 baud cable ?
Gr.
Dieter
Gr.
Dieter
