GM 8 PIN MODULE. BAD?
Old May 10, 2007 | 12:39 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
I recently had a short to a ground strap in my power wire to the msd, and coil batt power. It burnt up the dfi gen 7 harnes right to the computer. I repaired the harness and checked for shorts to the other wires. everything checked out ok. when i conect the harness back to the ignition module in the distributor (small cao dist) i get a short betwean the groun wire that toasted and both neg and positive to the module. Does anyone know how to test a gm 8 pin ignition module, without the ablitly to crank the car over. Any sugestions for other test would be great.
Old May 11, 2007 | 01:03 AM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Re: GM 8 PIN MODULE. BAD?
You can got to advance or vatozone and get it tested. You will probally have to do it your self because most of the time the people that work there dont even know what an ignition module is, let alone know how to test it. If it is shorted that bad the tester will tell you.
Seth
Old May 11, 2007 | 08:31 AM
Transmission: t-56
yeah they definatly do not know anything. I went there the part was 35 bux so i said ill just buy it, Then he tryed given me a ford tfi module, when i had the old one in my hands. oh well.
Old May 11, 2007 | 11:02 AM
Bigseth's Avatar
Yeah thats not too bad. The wells modules they sell arent that great but with a lifetime warranty you cant go wrong. Did that fix your problem?
Seth
Old May 11, 2007 | 03:34 PM
Transmission: t-56
Im not sure yet, i guess when the harness burnt up it was leaven the injectors open cause my cylinders were full of fuel. ill be sure to update when i runs. lol
Old May 11, 2007 | 04:23 PM
Bigseth's Avatar
Good luck with it. I had the same thing happen to me Iroc 2 weeks ago. But it washed the bottom end of my motor. So now Im going carbed for a while till I can get the funds for a new harness and a HSR setup.
Seth
Old May 12, 2007 | 10:11 AM
Transmission: t-56
Man that sux. Well i got all the fuel out, put a new set of plugs in. Cranked it over with the computer still disconected, and the thing fired up, weird enough, but was gald to see the engine itself was ok. Conected the pcm and it fired right over and ran beautifull. Im so glad that the dfi module held up to the herness burning right up to it.
Old May 12, 2007 | 10:41 AM
Bigseth's Avatar
Cool, Im glad you got it fixed.
wigmobile
Feb 26, 2025 02:56 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
