Code 34 and 42
Old May 28, 2007 | 07:47 PM
jcrules78's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: TPI 5.7L (L98)
Transmission: Automatic w/OD (700R4)
Axle/Gears: Stock Axle 2.77 gears
Code 34 and 42
Hey guys. I just took this whole weekend changing out my old blown engine for a newly rebuilt 350 in my 88 IROC. I drove it away today, and everything was great. No oil pressure issues, no trouble codes. When I came back out after eating supper and started her again, it took a bit of turning over before it started, which isn't typical for this car. Then I got the check engine light. It's giving me a 34 and a 42. I used to see the MAF sensor code pop up every now and again with the old engine, but I have never seen a 42. The code for 42 says something about check ECM wire in terminal 12 or HEI module is wrong. I did put on a new brass tipped cap, rotor and MSD Super Conductor wires. Everything was tight when I left. Any suggestions as to what could be wrong?
JCRULZ
Oh yeah, what does EST stand for?
Old May 29, 2007 | 08:56 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Code 34 and 42
'78
(EST) Electronic Spark Timing
For code 42 see this link
http://www.troublecodes.net/articles...ndrstd42.shtml
//RF
Old Jun 10, 2007 | 11:50 PM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
Re: Code 34 and 42
Checked out my car today also showing the same 2 codes 42-EST circuit open or shorted to ground during engine run, and 34-MAF signal voltage low during engine cruise I guess i be doing some searching my next day off
est is all the computers timing stuff: the knock sensor and its control module and all the wiring in between
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
