Differences in Spark Control
Old Jun 9, 2007 | 10:57 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
I wasn't sure which forum I should post but since I'm looking into buying a FAST XFI system and it has to do with that, I'll post it in here. I am wondering if anyone can explain the differences between IPU(Inductive Pick-Up) and Hall Effect. I want to switch my car to the XFI system, right now it has Speed Density with the small cap HEI distributor/external coil. I could stay with that system, but for sequential fuel injection the ECU needs a crank and cam signal. FAST sells a Dual Sync distributor that provides both signals. Is this distributor all I would need then? Need some information.
Old Jun 9, 2007 | 11:08 PM
388's Avatar
388
Car: oldsmobile
Engine: 3.88
Transmission: yes
Axle/Gears: yes it has axles
Re: Differences in Spark Control
I'm not definite with the fast but with my gen 7 dfi Yes, all i did was put in a dual sync and since it provides both signals I can run sequential mode.
Old Jun 10, 2007 | 05:49 PM
DJ406's Avatar
The dual signal distributor is all you need ( to run sequential) but I wouild recomend a crank trigger instead if you can pull it off. Its a much more stable source and makes it easy to set up the rotor phasing. unless its a full tilt race car the sequential wont make much difference .
DJ
Old Jun 10, 2007 | 09:42 PM
I have a Miniram manifold and I have noticed that the front sparkplugs are rich compared to the back sparkplugs. Other Miniram users have seemed to notice this too. I was wondering if I had more control over which injector was firing and when(individual cylinder control), then maybe it could remedy some of that.
eightsixseven
Dec 16, 2024 01:50 PM
g.l.mos
Aug 22, 2015 12:02 AM
justin57
Aug 20, 2015 07:05 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
