Help with code retrieval
Old Jun 10, 2007 | 02:53 PM
dsherw00d's Avatar
Car: 68 Camaro, 73 Nova, 67 Mustang
Engine: 350, 355, 289
Transmission: Muncie, 700R4, C4
I'm looking for some help retrieving codes. I hooked a jumper wire up from pin 6 (labeled F) to pin 12 (labeled L) and the SEL light just stays on when I turn on the key - no 12...12...12. Anyone know what could be wrong and what to check?
I need the codes becasue the car is running like crap - it seems to be flooding at low RPM and is sluggish. It will only start after it's warmed up by flooring the pedal. It runs better at higher RPM, but not real good. I've put on a fuel pressure tester and it's real good and stays that way when running and after it's shut of for 20-30 minutes. I just put rebuilt stock heads, hooker 2055s, and a Catco converter.
Thanks,
Dan
Old Jun 10, 2007 | 09:43 PM
dsherw00d's Avatar
Re: Help with code retrieval
I figured it out - using a guide that must have been for some other year. Once I juped the correct pins, it worked good. I'm getting codes 32 and 33. Any sugestion where to start? EGR and all sensors except knock and fan switches are new.
Thanks,
Dan
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
