Leg scpaing on memory adapter
Old Jun 24, 2007 | 02:29 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I am pricing out some the equipment I'll need for chip burning and I am unable to find what leg spacing the 746 ECM has. I know the options are .045 and .060, but which do we have? Is it not the same for all TBI ECMs?
Old Jun 27, 2007 | 11:09 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Re: Leg spacing on memory adapter
what are you ordering... I've never seen that option selection on anything on moates site or anyone else's site that makes tuning products for our cars.. are you ordering something custom or something?
Old Jun 28, 2007 | 11:23 AM
90c350's Avatar
Moates does have an option for .45 or.60 leg spacings on his site. I have just done this conversion and Im pretty sure that the 746 is the same as the 747 ecm's. I have also been told that most stuff is .60. I orderd the .60 and had no problems. You would have to verify this but I think that if you order the .60 it will work fine!! Or just pull up the main circuit board that the prom is attached to (you will have to do this anyway) and measure the pin spacing. I hope that this helps??
Old Jun 28, 2007 | 02:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It should be the .6 spacing. To measure you need to pop the little board free and on the bottom of the board measure across the two rows of pins.
The only ECM I've seen with the .45 spacing is the 1227148 (GN, TTA).
RBob.
Old Jun 28, 2007 | 05:55 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Thanks guys. .060 it is.
InfernalVortex
Apr 20, 2021 11:31 AM
Vintageracer
Sep 24, 2017 12:34 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
