Code 14 help
Old Jun 27, 2007 | 01:45 PM
rlapenna's Avatar
Car: 1988 Iroc Z Convertible
Engine: 5.0 TPI LB9
Transmission: 5 Speed
Axle/Gears: 3.08
Code 14 help
Hello,
I just bough this car, its an 88 iroc convertible, 5.0, 5 speed. It runs very rich and I had a code 34 (MAF) which I replaced and I had a code 14, Coolant temp sensor, which i also replaced but still have that code. I checked to see if I had powere on the two wires that go to the sensor with a test light. Should I or should I not have power here? Ive read some places that there is varying voltage depending on engine temp but should i have any power there in the key acc position? Ive also read that this would make the car run rich becasue it thinks its cold and dumps too much fuel in, any ideas? anyone?
thanks
Old Jun 27, 2007 | 04:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 14 help
The codes are stored in the ECM and won't go away until either the ECM power has been cycled off, or there have been 50 start-ups without an error.
For the CTS, with the connector disconnected from the CTS, turn on the ignition (engine off), and measure the voltage from each terminal to ground (engine block).
The yellow wire should have 5 volts on it.
The black wire should have 0 volts on it (it goes to the engine block as the sensor ground).
RBob.
Old Jun 27, 2007 | 08:24 PM
rlapenna's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 3.08
Re: Code 14 help
thanks, i will give that a shot. i suppose maybe i fixed the problem now i just need to get the code out. how can i cycle the ECM? the diagnostic book i have says to put the key on with the diagnostic tool connected, remove the ECM fuse, etc....thanks again for the help
Old Jun 28, 2007 | 11:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 14 help
The easiest method to clear the codes is to disconnect the battery for a few seconds (5 - 10). This also clears the radio settings, but they can be reset. I had to bring that up as I hear about it from my SO all of the time.
RBob.
Old Jul 14, 2007 | 02:53 PM
rlapenna's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 3.08
Re: Code 14 help
To anyone with this code...check the plug on the sensor. the garage I brought it to crimped the connections and the light went off. it appeared to have a good tight connection so i didnt think of it. i know that a lot of autoparts stores will sell the plug with the sensor, buy it.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
