Idle Issues!!!!
Old Jun 30, 2007 | 12:07 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
Idle Issues!!!!
my t/a has a 93 caprice c91 motor with the TBI unit , the ecm is out of a g10 van i believe 5.7TBI ok my problem is that my idle out of no where will suddenly jump to 1000rpm and stay i have to shut off the car and depress the gas pedal a few times and then its normal again , i replaced the TPS , Coolant temp , and cleaned the TBI unit multiple times , it does it randomly some days it doesnt do it at all others quite often plz help!
Old Jun 30, 2007 | 03:28 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Idle Issues!!!!
first check for any codes.
if it has codes, clear them & see if they come back, if they do, repair them.
if you don't have any codes or they didn't come back, your going to need to do some data logging to see whats going on.
if you have a laptop, you can buy or build a cable, get TunerPro & the right definition files for your ECM & mask & record some logs until it acts up. then go through the log to see if its something the ECM is doing.
Old Jul 13, 2007 | 09:28 PM
Car: 1985 TransAm
Engine: 5.0L TPI
Re: Idle Issues!!!!
ecm had its day replaced with a salvage unit no issues anymore
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
