How to ID an ECM
Old Jul 2, 2007 | 06:25 PM
atomicskr's Avatar
How to ID an ECM
Hello all, I'm fairly new to the forum and I need some help getting my car figured out. It's an '86 IROC with a 350 tpi (from a different camaro) and a T-5 (also not original to the car). The guy I bought it from said the engine came from a 1990 camaro but he is running a MAF on it. I've been having some minor issues with the car and wanted to make sure that the ECM is for a MAF car. I pulled the computer out.... where are the part numbers I need to look for and what should they be for a MAF car?
Any other ideas how I can sort all this out would be greatly appreciated.
Old Jul 2, 2007 | 08:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: How to ID an ECM
Look for the Service # on the label. Itwill be on the outside of the ECM. If it is the original it will be 1227165. There are newer service numbers for the same ECM. Not sure of what there are.
RBob.
Old Jul 2, 2007 | 11:12 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
ALMIGHTY Rbob, i have also looked for this number and the only number on the outside of my ecm i beleive worth looking at is 01220746, second 0 might be an 8. i dont remember. what is this number?
Old Jul 3, 2007 | 08:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is an 8: 1228746. Used from '89 through '92 on TBI f-body's. In '88 the 1228063 ECM was used.
The '8746 was also used on TBI Caprice's.
RBob.
Old Jul 3, 2007 | 09:46 AM
atomicskr's Avatar
I can't seem to find this number... would it be on a sticker or stamped into the case itself..... the only other number I found was 91-1088-77.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
