where is my ecu located?
Old Jul 6, 2007 | 05:53 PM
theCure's Avatar
Car: Looking
have a 87 trans am gta, took the panel off under the passengerside and saw nothing but the heater box? would it be on the driverside? or somewhere else?
Old Jul 6, 2007 | 07:08 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: where is my ecu located?
Should be on the passenger side.. Remove the bottom panel which does protect the heater box.. Then look up under the dash towards the speakers. Should be bolted in approx a 1 1/2 inch by 5 inch slot. Depending on your car S/D or Maf your ECM either a 1227730 or 1227165 will have either 2 or 3 plugs with lots of wires plugged in.
Old Jul 6, 2007 | 08:48 PM
theCure's Avatar
Car: Looking
i found it thanks, i was expecting it to be right there when you pop the cover, but i see they have it hidden pretty good...
oh also forgot one thing, im relacing my ecu with a 16198259 with an upgraded chip.....anything i should make sure i do when i switch it out, or is it as simple as unplugging the old one and plugging this one in?
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
6998poncho
Sep 25, 2015 02:56 PM
Nikole
Sep 24, 2015 08:12 PM
tonys91rs
Sep 2, 2015 07:07 PM
