DRP and injector firing vs AFR readings
Old Jul 10, 2007 | 02:42 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
When does the DRP occur?
As I understand when DRP occurs the ECM will fire the injectors right?
When you normally install a dizzy you point NO1 to Cyl NO1. What happens if you turn the rotor so No1 Wire points to No2 cyl, will this affect the AFR readings due to the injectors will fire too soon or too late?
Chasing a AFR error.......
/N.
Old Jul 10, 2007 | 05:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: DRP and injector firing vs AFR readings
/N.
Interesting question. The DRP occurs at the same time the timing light flashes when the EST connector is open. As having the distributor timed at 6 degees BTDC, or whatever it is set to.
The injectors are fired once every engine revolution (sometimes every other, but we will stay with once per revolution). The ECM does this by counting DRPs. And, it does not know which cylinder the DRP came from.
So the actual batch firing of injectors can occur on any cylinder. It all depends upon which cylinder is the first to be counted. For the firing order 1 8 4 3 6 5 7 2, if #1 is where the injectors end up firing, they will also fire on #6, four DRPs later.
If #4 is where the injectors started off, they would fire again on #7, four DRPs later.
When the engine is shut off, the ECM has no knowledge of what cylinder is at TDC firing stroke. Then when the engine is cranked and is now running, the ECM has no knowledge of which cylinder it started with.
RBob.
Old Jul 11, 2007 | 01:55 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Damn, I though I had come up with something that could be the cause for my problem....
Well thanks for the great explanation RBob!
/N.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
djmarch
Aug 9, 2015 05:27 PM
