730 to 749 ecm swap
Old Aug 13, 2007 | 02:39 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
730 to 749 ecm swap
ok i dont know anything about ecm's, would this be a smart move, i am running a zz 383 with a procharger and havent had it tuned yet, or even had a custom chip for it. do i need a custom chip since the 749 ecm works with superchargers and turbos? or would u say i even need to swap ecms? thanks,bryan
Old Aug 13, 2007 | 03:00 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: 730 to 749 ecm swap
You dont need to swap ECMs, the 730 and 749 are almost identical, the difference is just some injector drivers. Bottom line is.. you can run the 749 code on your 730.
Youll have to move a couple wires around in the ECM plugs and buy a moates adapter to put the syclone/typhoon binary on there.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
