Need help with data logging hardware/software?
Old Nov 21, 2007 | 09:20 PM
  #51
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Re: Need help with data logging hardware/software?
ya your base timing is set to 89 degrees, i think thats some of what youre looking at
often tuning places seem to put a quick bandaid solution on the tune cause it takes too long to do it properly
Old Nov 21, 2007 | 09:27 PM
  #52
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
nah I have no way to get a copy of my stock bin...Its in stock form and not in a chip. ...Hmm? about the timing, Im wonderin if thats one of the reasond Ive never been able to set timign the corrrect way....but let not get off track.
I wish some could edit it the way they thing it should be...I have not idea where to even begin...
I dont know anything about chip burning or programming but you see what I have and your even saying thats CRAZY! as to what my chip has in it.
I wish others would chim in too.maybe I should start another thread? should we be in the DYI prom forum?
Old Nov 21, 2007 | 09:39 PM
  #53
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
you might want to start a new thread about this in the diy prom board
and read everything here
https://www.thirdgen.org/forums/diy-...uide-book.html
chapter 5 read all of the articles on your ecm a dozen times until they start to sink in a little
lol beat me too it, ya man ask them im not experienced with ur ecm
Old Nov 21, 2007 | 11:17 PM
  #54
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
there is alot of info on the 8D mask and 730 ecm but not much listed for the MAF 6E. there is a nice article on the 32b tho. Its kinda sad there is no links to the 6E maf system like the 8D.
is it really that inferior? i know maf can be easily maxed out but with PE tables allowing fuel addition after the MAF is done, it seems like there is no reason to convert to SD
Old Nov 21, 2007 | 11:31 PM
  #55
I compared my bin with the arap bin that comes with tunerpro jsut for kicks and my bin looks so ****ed up compared to the arap bin .. I think this bin is screwing my motor up!
in mine all nthe values looked maxed out...everything is either set to 255 or 89 and some other BS!
like where number of cylinders? its suppose to say 00 for 8 and mine says some BS like FF
Old Nov 21, 2007 | 11:37 PM
  #56
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
wow thats interesting. you sure its the right bin and XDF file to compare the values for?
Try swapping in a arap stock bin on the car to see how it runs. naturally it wont be optimal for that 383 but maybe it will hint to better run quality
Old Nov 21, 2007 | 11:46 PM
  #57
yeah its the right XDF file...its says it in the text..its the expanded 6e ..I even tried the regular 6e and its the same.
I read my chip a few times just to make sure and it still comes up the same...I want to go out and see if the chip still runs in the car...I mean Im sure it does but I cant seeing my car is do freaking loud!!!!!!..LOL
but yeah thats what comes up when I read my chip.
the arap.bin is for what kind of car?
before I got the LSR chip I couldnt even idle the car with my 305 chip.
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
