best tpi computer
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
best tpi computer
i have an 89 maf tpi , im having trouble finding a aftermarket computer(just the comp and hook ups needed to put on an existing tpi) which is the most affordable and easy to use , and where could i get one.
Re: best tpi computer
i mean like a fast xfi or accel dfi, or maybe a custom chip would be best. anyone?
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Your best bet is to purchase a factory ECM and program your own proms. If the engine is pretty well stock just stick with stock programming. That's pretty much the cheapest and easiest way to go.
Car: 1985 Trans Am
Hi the names Caine. You seem to know alot about Fbodys and Im still learning so if I could pick your brain I'd highly appreciate it.I have a 85 tpi transam and I just dropped a new 87 camaro 350 in her and heard i need to change the fuel injectors get a new calibrated prom chip and get a new ecm to see the 350's true performance. Is this true? And if so would you happen to know a good maker of these parts to better benefit my 350's performance. Any help is highly appreciated
thanks
Caine
thanks
Caine
Sanjay
Aug 12, 2015 03:41 PM
383, aftermarket, besttpicomputer, computer, ecm, fasts, gen, good, maf, motor, performance, stroker, tpi
