Air/fuel Is NB O2 reading accurate enough?
Old Jan 11, 2008 | 08:04 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I just went back to the "adjusting air fuel with O2 sensor and voltmeter" tech article and have been looking into WB vs NB O2 monitoring and am wondering;
Is the NB reading accurate enough to adjust fuel pressure?
Here's a chart I found:
Gauge READING FULL THROTTLE AIR/FUEL RATIO
.000 17.0:1
.100 17.0:1
.200 16.0:1
.300 15.5:1
.400 15.0:1
.500 14.7.0:1
.600 Dangerously Lean 14.6:1
.700 Getting lean 14.5:1
.800 Max power(Lean) normally aspirated 14.2:1
.875 Max Power normally aspirated 13.5:1
.900 Max Power (Rich) (NOS,blower,Turbo) 13.2:1
1.000 Very Rich 12.5:1
I have an accurate, fast acting voltmeter and am getting readings in the high "700's" at full throttle. It appears I'm running a bit lean according to the chart above.
Will using this be good enough to get me in ball park?
KiLLJ0Y
Jun 28, 2003 02:57 PM
89 Iroc Z
23
May 11, 2003 02:17 AM
BOTTLEDZ28
Oct 7, 2002 08:35 PM
Zepher
Jul 3, 2002 10:47 AM
