1bbl TBI off 8625
Old Mar 24, 2008 | 07:46 PM
walkerscott's Avatar
1bbl TBI off 8625
I am having trouble finding infomation on running a 1bbl tbi on a 16168625 ecm ... which ius setup for 2 tbi injectors ...
Does anyone know where i can find information ... or can someone provide details ...
ROb thanks for your help BUT were scrapping the port injection unit into the 2 runner manifold for that 4 cylinder.
I was trying to run port injection on a siemized 4 cylinder project but was unable to get out stumble .. we think it has some thing to do with injector timing and valve timing ....
so TBI should work if i can get the ECm to synch injectors not Asynch
Old Mar 25, 2008 | 07:59 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Re: 1bbl TBI off 8625
Are you looking to run the engine with the single TBI 1BBL, or 4 of them?
if you are trying to run just one, you could swap to a '730 ecm with the right 4 cyl cal, unless you really need the '8625 to run an e-trans.
Old Mar 25, 2008 | 12:21 PM
yes running just 1 1bbl tbi unit an prefer to stay with the existing ecm for trans control
HELP?
Old Mar 25, 2008 | 02:44 PM
jwscab's Avatar
Engine: Many
from the documents I have read, in order to run every DRP, you would need to apply +5v (VCC) on the memcal to pin 13 of the 16 pin netres. I beleive pin 12 is VCC.
Old Mar 28, 2008 | 03:55 PM
Got it Thanks tried it and yes every DRP it fires THANK YOU
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
