electronic advance timing
Old Mar 31, 2008 | 10:06 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I am curious as to how that is controlled. IF I have a improper working chip will the computer not advance timing? What could happen if a chip is bad? Im kind of stuck right now and im wondering what are some issues with bad chips
Old Apr 1, 2008 | 06:26 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: electronic advance timing
If something goes wrong with the prom/memcal the ECM will go into limp mode, which will cause the SES light to stay on. Or, if there's a bad connection at the memcal socket (cracked solder joint, etc), the SES light may flicker randomly, I had that problem. I'm not sure if the ECM still advances timing in limp mode, but I think it does. I think I remember reading that in limp mode the fans stay on too. Have you checked with a timing light to see if the timing is advancing?
Old Apr 1, 2008 | 06:44 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
no advancing at all. It really is getting on my nerves. I am about to just put the megasquirt in now.
Fast355
Dec 2, 2016 06:33 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
