swapping stock ECU PROMS between manual/auto
Old Apr 3, 2008 | 03:15 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
quick question...my ecu in my 1988 Pontiac Firebird (305 TBI / manual 5 speed) went bad (wouldn't engage fuel pump relay). Needed to replace it, found a 1988 Pontiac Firebird Trans Am (305 TBI / automatic 4 speed) ecu that was good. Swapped the prom and noticed that there was a second chip in the panel that my haynes manual did not show. Do they need to be swapped auto to manual and would that second chip ever go bad that i should take it out of the second ECU before scrapping? It's running off of the Trans Am ECU with the manual PROM swapped into it w/out touching that second chip, but i wanted to know breifly what that was for and if i should have a spare.
Old Apr 3, 2008 | 03:51 PM
Ronny's Avatar
Re: swapping stock ECU PROMS between manual/auto
I believe it is a calpack. Provides the "limp home" mode of operation should the chip fail? Should be present and should match V8-V8.
Old Apr 3, 2008 | 04:09 PM
84redta's Avatar
any reason it'll ever go wrong, would i recognize as i break down on the side of the road that i can't limp home, swap the chip and limp along?
so your saying that the "limp home" chip matters v6 to v8, not manual to auto? just clarifying, thanks!
Old Apr 3, 2008 | 04:14 PM
Ronny's Avatar
I dont believe the trans matter. I had a V6 calpack in my ECU with a moderately modded 350 and when the chip became displaced from ecu(by foot) car would still drive just poorly.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
