Puzzling Trouble Codes?!?!?!
Old Apr 4, 2008 | 08:05 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Transmission: Manual
I just ran my codes and I got a 22, 34 and 44. I looked them up and came up with:
22 Throttle position sensor error (signal low)
34 MAP sensor circuit error (signal low indicating high vacuum)
44 Oxygen sensor error (lean condition indicated)
My car is an 87 T/A LB9 With a manual Trans
This is a MAF car I thought, Any thoughts how I could have a MAP error?
Old Apr 5, 2008 | 08:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Puzzling Trouble Codes?!?!?!
The code 34 listed for the MAP is really for the MAF sensor. It is the same basic description though: MAF sensor reading is low. This can be caused by an air leak as it won't be metered by the MAF.
Before replacing any parts check the grounds on the back of the passenger head. Then do the tap test on the ECM & MAF. With the engine running tap on each. If the engine stumbles or otherwise changes how it is running then that part is most likely bad.
RBob.
Old Apr 5, 2008 | 01:57 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
I think I am one step closer. I pulled the MAF and found that there ate two filaments. The short thick one is fine. The thin as a hair fliament that runs all around is broken. That may explain at least part of my problem.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
