MAF gram question
Old Apr 9, 2008 | 02:40 AM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
MAF gram question
Hello I don't know if this is a problem or if it is normal. When the engine is off and the ignition on I'll be looking at my laptop that is connected to the car and some times the MAF grams will jump from 5 grams to 30 or 32 grams. It doesn't do this much and when it happens its only for a frame. I recorded it doing this if you want to see it I used TunerPro RT with the 165_6E.ADS You will see it right at frame 197
Is this normal??
The link is to the file I had already posted in Tech / General Engine.
https://www.thirdgen.org/forums/atta...-89gtatest.zip
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
