Can the ECM make the car not run or run rough?
Old Apr 16, 2008 | 05:40 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
I pulled the brown plug with the black stripe to time my car because it has been running rough and knocking. Also won't start back up sometimes. So I time it with the wire unplugged get it running smoothly at 6* BTDC, hook the wire back up and it won't stay idling. Plus when the wire is hooked up there is my knock. When it is unplugged there is no knock. It is a 1992 Z28 305 TPI.
Old Apr 17, 2008 | 03:57 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Can the ECM make the car not run or run rough?
maybe your ESC module is bad..
how much timing do you get when you plug it in ? Do you got any SES codes.. do you have the ability to hook it up to an laptop and scan it ? if you do, please do it and upload the file here and ill check it out..
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Sherpajames
Aug 7, 2015 06:56 PM
